I know I need to go and do a block test and pressure test it to eliminate all possibilities.
With that said, the car doesnt over heat, but If its driven over 30 miles, it will start to spit the boiling coolant into the birdcage. Temp sensor reads a line or two below horizontal.
Aside from the obvious BHG(just rebuilt and better not be or the machinist can redo this motor on his penny)
I saw the nipple on the radiator going to the birdcage cracked off and the hose was placed on there in a mediocre fashion, enough to get the fluid to the reservoir, but most likely not airtight. Would this cause some pressure loss and create the boiling fluid?
