Body Work Experts!! I need your help!
MK3_Turbo
JZZ31
Arkansas
well i just need to know how to fix the clear coat that is peelin off the driver side door and a little on the hood. it makes my supra look dirty and ugly.
do i just sand it down and re-clear coat it?? :1zhelp: a step-by-step procedure would be helpful and nice...
thanks in advance!!:icon_bigg
mattjk
Permanent Ban
May 18, 2006
1,973
Huntington Beach
pm johnathan1 or is it johnathon1?
he's like the clearcoat/paint/colorsanding expert.
johnathan1
Supra =
Aug 19, 2005
5,056
Haha Matt...
It would be best to sand the remaining clear off, and respray it, but you can get by with wet sanding the remaining clear off, (1000-2000 grit) and buffing the paint underneath, and then sealing it with a good wax.
Adjuster
I'm with Rajunz, don't screw around and waste your time wet sanding and buffing just to have it haze out and peel at the edges. (And anyone who knows what they are looking at will see this in a milisecond.)
If you do not want to repaint the entire car, just fix the panels where the clear coat has failed. (New matching color, and clear coat.)
Just make sure you remove your trim, and do a good job. Nothing looks worse IMHO than fresh paint and shitty masking work. (Why bother?)
