valve seals, rings, turbo. those are the areas i would look into. do a compression and leak down test. read your plugs. i would think that if it was turbo seal the oil is spraying into the exhaust not the combustion chamber. i could be wrong on this but i would reason that if the oil in in the combustion chamber(without having oil in your intercooler or pipes) then that rules out the turbo seal. the next thing would be to determine whether its valve or ring issue(compression test). if i am wrong about the turbo thing someone please explain why. thanks, hope that helps.
