Ok I'm not a noob I know how Intercoolers and aftercoolers work but here is the deal..
Im thinking of using a m112 eaton roots blower on a 1uz. like this..
On the Ford lighting it is cooled with an Air to water aftercooler that is placed INSIDE the intake plenum like this..
It works by pumping water through it which pulls the heat out up to the front of the truck to be cooled by the heat exchanger.
Now that system is way too complicated for me to even attempt. but how would this work.. running a traditional FMIC with a K&N on one end, then plumb the other end all the way up to the Throttle body on the blower?
I realize that the air will be cool before it gets to the blower, and probably get heated up once it passes through and leaves the blower, but how fast/much could the blower possibly heat it up?
