Bee*R wont let me rev passed 3000 rpm
super.secret.supra.club
1,304
San Diego, CA
hello,
i have installed a bee*r rev limiter on my 1jz gte from a jza70. i am wondering why the limiter wont let me pass 3000 rpm even with the Rev 1 setting at "F".
i have followed the article to properly installing this unit and still no luck
http://www.supramania.com/forums/showthread.php?t=74363
has anyone else run into this problem?
what did you do to fix it?
please share your thoughts as to what the problem may be.
thanks in advance
ed.d.
JesseH
1,153
Englewood, Ohio, United States
super.secret.supra.club;1488967 said:
hello,
thanks in advance
ed.d.
where is your second rev wire installed? Also, you dont have any of the looped wires cut do you?
1,304
San Diego, CA
i got the problem fixed. the wiring on the article was incorrect. the green and yellow wires are switched.
to answer your question, the white wire is a parking break switch. the limiter will still work without the white wire connected to anything
JesseH
1,153
correct. Ive got one of these too. I've helped a few people with them before, one situation they had the white wire wired so the rev2 signal was always active...
I had the same problem as you did though, the only diagram I found for the 7m had them backwards also.
