I've measured all of my journal diameters on the crank and have the following:
Mains
1 - 2.3624
2 - 2.3623
3 - 2.3621
4 - 2.3621
5 - 2.3623
6 - 2.3621
7 - 2.3621
Rods
1 - 2.0467
2 - 2.0467
3 - 2.0466
4 - 2.0467
5 - 2.0468
6 - 2.0468
Great! All within spec, but I'm planning on getting my crank polished and am a little worried about the mains with a 2.3621 diameter. Toyota spec is 2.3620 minimum and I'm afraid that polishing may take off too much and go below spec. I'm trying to avoid grinding the journals down and using undersized bearings since I've read that the crank is hardened and you will lose some of that when grinding too much. Will I be safe ordering standard size bearings? I'm thinking about running on the high side of the spec anyway, giving it about .002" clearance which might work out with my situation...I'll be looking at 500-600+ rwhp on this build (http://www.supramania.com/forums/showthread.php?98230-Bearing-clearances-vs-oil-viscosity). Any input on this? I'm planning on running this by my machinist as well (obviously), but I wanted to get some of your guys' opinions on this too since I know the 7M can be a very picky beast .
Mains
1 - 2.3624
2 - 2.3623
3 - 2.3621
4 - 2.3621
5 - 2.3623
6 - 2.3621
7 - 2.3621
Rods
1 - 2.0467
2 - 2.0467
3 - 2.0466
4 - 2.0467
5 - 2.0468
6 - 2.0468
