I just got a gt3582r. Is it sensitive to tilt the "bearing section/mid section" (dont know in english) for the lubrication? Is it ok to tilt 20 degrees? And you guys with bb turbo have you any extra filter for the oil.
IMHO 20* is ok... the main rule is: oil should drain without problems...
I don't run oil filter (have discussed this via PM with dbsupra.. he knows what he talks about and he said that filter is useless) but run 0.9mm restrictor...
