+ Battery wire connection
VooDoo
Draggin ass on his build
Mar 20, 2008
342
Valdosta ,Ga
Well got my battery box in the trunk. Run my wire. HOWEVER I see the wire from the starter but there is another wire that connects to the + as well. Anyone have a picture of this wire as well as were it leads to. I am afraid I removed it thats why I cant find it. OR i have it mixed up with another wire. If im not mistaken it goes to the fuse box under the hood correct?
radiod
1,342
Abbotsford, BC
There is a direct line from the battery to the starter and it should stay that way. The blue wire bolts to the under side of the starter and is the supply for cranking.
The other wire running to the starter (black/blue stripe with a brown clip IIRC) is for the solenoid and comes from the starter relay.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
are you talking about this wire?
If so, the + wire only attaches to the starter. The other wires are (-)
VooDoo
Mar 20, 2008
342
Valdosta ,Ga
Thanks. I was sure there was another + connection. Is there no more wires coming off the + post to feed the ECU or Fuse box? Had I known I was gonna go this far with the car I would have kept better track of the Battery situation.
