base map of speed density maft-pro.....
black91turbo
Formerly black87turbo
Apr 27, 2006
1,064
Jacksonville, FL
I ran out of money for the turbo so i have to tune it the way it is.....With the Precision 680's, RonR FFIM and a stock CT....I have a FPR, walboro and all other supporting mods. I just need a base tune....anyone?
Fletch124
2jz swapped!
Jul 17, 2005
1,282
Reno, Nevada
You pretty much already have a base map. All you have to do is enter the settings from the installation manual for the MAFTPRO. Then just either learn how to use Tunerpro or just adjust things on your MAFTPRO box.
Another option would be to find someone whose really good with MAFTPRO and is willing to send you revised maps. You'd just have to log idle, driving around, then boost. And they will alter a map for you and all you have to do is upload it. Log it and have the map tweaked again.
americanjebus
Mr. Evergreen
wa.
your car came with a base map on the stock ecu dude.
Maftpro just tweaks it, thats its purpose.
All you need is to change your mainscale to adjust for the change in fuel supply, change your throttle body size to about 7 maybe 8. Get a wideband and start adjusting to satisfy VF.
