base map 2j on 7m?
tromspert
86
PA
Hey guys if I were setting up a new ecu or piggyback and I have a 2j running on 7m electronics should I use a 7m base map? anything I should change? thinking of redoing my tune from scratch and just needed to know if that was the correct base map to use. I am running a maft pro currently but plan to change it eventually.
toyotanos
What will we break today?
2,841
Coon Rapids, MN
Everything is going to be different, so you'll have to play it safe until you have the tune adjusted for the different engine.
Be careful, you can melt an engine quickly if you're not!
tromspert
86
PA
anyone have any idea where i'd start with that? or have a map in particular they used and I can work with to start as a base?
I wasn't sure if I should be using a 7m base map or a 2j one, it's driving me nuts haha.
toyotanos
2,841
Coon Rapids, MN
I'd use whatever 2J map data you have, as it'll be closer than a 7M map. If you have nothing aside from 7M stuff, you can try to start with it, but just be careful to go over everything before running boost.
tromspert
86
PA
well I run between 10-13psi on average with current fuel restrictions. I'm probably moving to a ecumasterusa piggyback. They have a build running near identical to mine and have the maps for it. Not to mention it's a hell of a better piggyback than the maft pro it seems.
