After a full engine rebuild, the car don’t run well. I’m still working to find the root cause with out luck, so I need some new ideas and suggest to find the Fproblem.
Before the engine rebuild, everything work fine.
Full Engine rebuild: 7MGTE
Stock ECU running with MaftPro with 3 Bar Map
550 RC injectors
Walbro fuel pump with 12v Mod.
Now: Running like Sh…
Vac pressure from: 10 to 12 vac pressure at idle.
RPMS: 600 ~ 750.
Vf voltage: 0.01V
TPS:0.51 V
A/F: 18.0
All injector work
Have spark in all wires.
I already check:
Wiring ECU to sensors
Ground
No error codes.
I already check and pass the test of:
Ignition Coil pack
Ignition wires
Igniter
TPS
Injectors
Injector solenoid resistor
Water tem resistor
ISCV
Fuel pump: 29 psi with vacuum
Cold star injector
Cold star injector Time switch
Water temp sensor
OX2
Replace:
Spark plugs
Fuel Filter
Gasket of the lower, upper Plenum and TB.
The mechanic said that could be a air leak, But I Don’t find any one.
What I did:
Replace some gaskets.
Connect only the hose to the MAP sensor and gauges
Block off break booster hose, blow off and power steering.
Check injector.
With out luck!:cry:
So What can I do? :1zhelp:
http://www.youtube.com/watch?v=QsjWREu_Qew
550 RC injectors
RPMS: 600 ~ 750.
Vf voltage: 0.01V
TPS:0.51 V
A/F: 18.0
All injector work
I already check:
Ground
No error codes.
Ignition Coil pack
Ignition wires
Igniter
TPS
Injectors
Water tem resistor
ISCV
Cold star injector
Water temp sensor
OX2
Replace:
Spark plugs
Fuel Filter
What I did:
Check injector.
With out luck!:cry:
