bad 1jz problem that we cant figure out
Boostage
323
Florida
Specs:
1jz
Blitz ecu
Sard 620cc
SAFC II
Problem:
Car was done 3 weeks ago, and Dyno tuned Last week. everything was 100% perfect. but had a weird oil pan leak. we drained the oil, removed the pan, and resealed it. added fresh oil. then cranked it up. then all of a sudden the car was dumping fuel bad, and would stall. it now does this everyday until the car is completely warm then the problem seems to go away.
Parts that were replaced over the next few days:
IACV
MAP sensor
Coolant temp sensor
TPS reads fine on the safc so its not TPS. every sensor including Air temp was tested. Opened up the ECU. no leaky caps or discoloration anywhere.
When cold the car runs so rich that it fouls out the spark plugs and you can smell gas in the oil. if you try to drive like this the car bucks badly and will die every time you come to a stop once warmed up the problem eventually goes away. what is causing the car to run super rich and die when cold?
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
Have you tried running it with the stock ecu just to rule out if it's the blitz. When I tried my friend's blitz ecu my cold idle speed was so aggressive (smells fuel everywhere) till it's warmed up then idles fine drives normal. Werd.
Are you running stock 02 sensor? Not sure but I think the blitz don't like my mustang sensor. I read in the mr2 forum someone who had a blitz that have the same problem but when he switched back to stock 02 sensor his car idles/drives fine cold and hot.
Boostage
323
Florida
Stock ecu will not idle with a safc plugged in as its intercepting the MAP signals. and if u unplug the safc the stock ecu will not idle 620 injectors. there is no way to use a stock ecu to rule out the blitz unless it gets dyno tuned all over again. but as I said I went inside the ecu and it looks fine. also O2 is brand new
OneJSupra
I'm a sleeper ...
Feb 9, 2007
900
Supraland
My car idles fine (14.7 afr) stock ecu with the 540cc with only -12 fuel correction in the safc. If I zero it out it would stall. I can't imagine even with the 620cc the safc can't control it at idle speed. I guess every car is different. There has to be something else causing it to run pig rich. Maybe it's your safc, just throwing some ideas here ... g/l.
JonoTurbo
Going for broke
CT
Even though you opened the ECU and looked, unless the caps have been replaced I'm still gonna say ECU. Usually when you get a problem that comes out of nowhere it's the cause, and the caps can be bad without looking bad.
Boostage
323
Florida
Ok but why would it run perfect again after its warmed?
JonoTurbo
Going for broke
CT
Because only the open loop portion of the fuel circuit is damaged.
I'm not saying this is definitely the case, but the 1jz ecu's fail all the time and I wouldn't rule it out.
Boostage
323
Florida
Tonight I tried my blitz in an sc300 with a 1jz and the idle was PERFECT, put the Lexus ecu in my car and the problem was still there. so we know its not the ecu
JonoTurbo
Going for broke
CT
Well that's one way to rule it out. :)
I'm just throwing these out there as things to check: the ISC, and the cam sensors. You seem to have covered everything else.
OneJArpus
2,798
when i did my 1j swap i had a sard ecu, i finished everything and it wouldn't start, it would stumble for a few seconds and crank but would never fully fire. I sent the ECU to DM and Aaron said that the board was perfect but the blitz board added was screwed up and he couldn't fix it cause he didnt know the specs of what was on the board. I ended up borrowing an ECU and it started right away. i took my wiring apart 4 times thinking it was that but i did ti perfect the first time to find out the ECU was shit.
