Aux fan holes in shroud
Zrain25
639
Pelham,New Hampshire
Ok so I removed my Ac system while doing the rebuild. Have a aluminium rad now and a new shroud on the way. I'm not gunna installing the two little Aux fans... Should I leave those spot open or find a away to seal them up do the fan has more of a sealed shroud too pull air
8,873
If you are not using the electrics, then the shroud needs to be altered as you suggest. Why remove the electrics? They also come on when coolant temps are too high.
