I could figure out if this was more appropriate here on in the transmission subforum. Well this does have to do with lubrication. Im picking up another auto soon and i plan on shimming the accumulators while its out, changing the strainer too. Also i plan on installing a cooler for it. I was looking at the B&M 7.5"x11"x.75" cooler. Is that sufficient enough to keep things cool. I was looking at that one specifically as i can mount it in front of the intercooler withouth and and be able to run some rubber hose to it. My other question is Since the Cooler has 3/4" inlet and outlet and the stock tranny lines arent that big (i dont think?) Can i use a reducer from 3/4" to the stock line size? Or would it be better to run all new lines from the transmission. If so any suggestions? As accessing the transmission cooler lines are a bit of a pain. Also plan on putting Redline Dexron II ATF in it, friend is getting it for me ( i know im getting a lot of free junk lately).
Second Opinion Welcome
Thanks for reading
~JDMMA70
Thanks for reading
~JDMMA70
