I'm in the final stages of wiring up my 1JZ swap. I'm going to be using a Holset HE351CW turbo and Map-Ecu2 for my engine management. I only plan on controlling fuel initially but eventually plan on doing timing as well. I attatched the file to wire the Map-Ecu2 into the 1JZ harness and I'm curious if any of these wires are shielded? They are:
Fuel
BT- Switched Power
E2- Earth for 1,2,3,4
VTA1- Throttle
PIM- Vacuum Sensor
OX- Oxygen Sensor
E1- Ground
Timing
IGT1- RPM
IGT2
IGT3
IGT4
IGT5
IGT5
Any help would be awesome. I'm not sure I want to mess with shielded wires if I don't have to.
Fuel
BT- Switched Power
VTA1- Throttle
PIM- Vacuum Sensor
OX- Oxygen Sensor
E1- Ground
Timing
IGT1- RPM
IGT2
IGT3
IGT4
IGT5
IGT5
