The Neo can only Alter in your case (1jz) the stock Map sensor signal. As Doc pointed out, the Emanage can directly control injector duration and timing, plus it had the advantage of being able to use its own (additional) 3 bar map sensor, so you can tune beyond the stock map sensor range. Becuase it directly controls injector duration you have far greater control over fueling and Injector sizing.
