anyone using a Holset HX-35 from a 94-02 Dodge Ram Diesel?
Krister
Holset lover
May 2, 2005
159
Finland, Europe
MDCmotorsports;888298 said:
Stop thinking in Garrett terms. That turbo is a monster spool magnet and has enough air flow to make 425hp+.
I might give this turbo a try with the stock 48mm intake wheel first and see how it works, but it still is a little mismatched with the exhaust wheel. I'll post pics of the turbo when i receive it next week.
Have you used one with these wheel sizes?
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
when did the HX35 become a 48mm wheel? i thought it was a 52mm inducer? that turbo you have sounds like the one thats on my truck, with the 12cm housing and all...
what do you say john? im gonna pm you...
DavidBaustert
Dayton Ohio
Krister;888899 said:
HX35 are not ball bearing turbos, maby they have offered one at some point, but 99% of HX35 are journal bearing type.
Hmm...I remebr reading on a dodge forum about that. sorry. what is the difference in the WH1c and the HX35?
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Krister;887860 said:
Anybody running a HX35 in a 1JZ? I just bought one as a spare if my stock twins will blow up. It has a 48mm intake and 60mm exhaust wheel and a 12cm^2 housing. I might have to have the intake wheel changed to something that fits the exhaust wheel better, maby a 52-54mm wheel.
I will be when I can get some more money together. I have almost everything together.
Lets see what a $40.00 used turbo with no shaftplay can do with a 1j and some 550s (all other supporting mods in place).
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
i think ive decided that im going use Later Holsets from either 03-04 Dodge diesels or some from 04.5-07 dodge diesels.
they are supposed to be an HX/HY35 class turbo, just different peripherals. the wheels are alleged to be the same so they SHOULD have similar power potential. so, after that, im going shopping for some HE341's or HE351's. id like to keep them internally gated but i would need to get much softer WG actuators. i think the stock ones are for 30psi. or 28psi ish... 3.0PR according to Holset's article.
foreverpsycotic
Back in the game!
Jul 16, 2006
3,171
12
ATL
Soon, I am saving up my cash right now, as I need to get everything installed, and some things welded up. Give me about a month, and I will have a graph for you guys.
BTW, does a -3AN feed without a restrictor sound about right?, or is that still too much oil?
mk3713
Up for sale
Nov 29, 2005
97
Houston
It probably will still smoke on start up with a -3an fitting. I am still trying to fix this problem on my holset but no success yet. I have a -4an fitting and -10an return btw still smokes when cold.
Sideways_bob
62
KY
flubyux2;821525 said:
yes, yes and yes.
i have a huge air filter. the BHAF mod. its bigger than a gallon jug. its a 4" turbo back, no cat and no muffler. the turbo feels like new; very tight. i also have a modified #100 fuel plate... since mine is a 12valve. i cant use programmers.
btw, i found an H1E for $500, a new HX40 and a new HX35 for under $400 i think. i also found used BD Super B turbos which are modified HX35's using Borg 61mm wheels, or 62mm. i cant remember. whats the deal w/ an H1E? im not familiar with those...
Mine is a 12 valve. I have a PPE pump, rpm springs, ect ect ect
I don't know how many pounds Im running cause i just wrap my boost gauge.
flubyux2
Madd Tyte JDM yo ®
Apr 2, 2005
1,019
st. pete, fl
I have he same problem; my boost gauge doesn't go high enough and it's a 30psi unit. I think I broke It too, it doesn't rest at 0 anymore. I really want new gov springs too. That's all it really needs to haul serious ass. Anything else will require alot more work like a turbo, injectors, dv's, studs, and so on. The next level is a big step. It should be in the 14s easily as it sits, which is pretty serious for a 6000lb truck.
What year is your truck anyways?
