I just had my engine put back together, and it was having trouble starting and would stall very easily. I figured it was my MAF because when I would try to start it with it plugged in it wouldn't start and it drove nicer without it but it still wouldn't get above 3k rpms. I figured I would drive over to the nearest advanced auto parts to see if they could use their meter to see if I get any codes and they didn't have one. So, on my trip back home the car is trying to die. It wouldn't go above 40 and every time I changed gears it would shut off and come back when I engaged the gear. I pulled over to the side of the road to let it sit for a bit and then check later if it was all right and now it doesn't start.
I also noticed oil had leaked in spark plug chamber from the valve covers. I then had them sealed up properly and got it running. After getting it home I took it apart and realized then that my cylinders had horrible amounts of oil, my spark plugs were covered in oil, the spark plug wires were disfigured. So I cleaned out all the oil (to the best of my ability) changed the spark plugs and wires and nothing. Thats when I went to check the ignition.
I tested the igniter, CPS and a million other things and it lead me back to checking the spark plugs. I pulled the number 1 spark plug and held it to the ground and no spark. Whats wrong?
