Anyone know what engine seal this is?
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
I recently bought the OEM Ishinu gasket set for the 7mGTE motor and I am looking through my seals and I cant seem to find what this seal is for. It came in the small bag with the valve stem seals and has the same dimensions as a camshaft oil seal. I am thinking it might be a seal for a non turbo distributor and it just put in there as a extra seal. Thanks.
sheedy126
Boost Addict
Apr 30, 2012
716
kennewick
Could be for the oil pump intermediate shaft. Iirc they are the same dimensions as the cam seals
Sent from my SM-J320V using Tapatalk
May 17, 2016
33
Melbourne, FL
I think I remember seeing that in my gasket kit too, but I didn't end up using it for anything. I can tell you that it is not for an N/A distributor because that is just a simple o-ring.
Aug 24, 2009
126
Nirvana
That's for the oil filler cap. Man mine was so toasted lol hard to get out of there.
BTW I got that same Stone kit and the EGR gaskets didn't fit, or were non-existent. Same with the cold start injector. Ended up making a cold start injector gasket out of thick card paper (using sealant on it). EGR needs to be a high temp gasket though. Found them at Oreilly's.
plaaya69
87T Supra
Nov 18, 2006
947
7
Lake County, IL
Thanks for the replies. Yes, it is for the OEM oil cap. I could not tell because I have a aluminum TRD oil cap going on and it only has a small o-ring on it and I have set my OEM oil cap aside.
