my anti-lock light is on...i think i might need some new brake pads...but i'm not sure. it been on ever since i bought back in January 2004 but i'm not quite sure what it is. :icon_conf
GrimJack said:Hmm.. I was under the impression that the E-brake light comes on when your pads are low, not the antilock light. Wouldn't make much sense to use the antilock light, as not all cars came equipped with the antilock option, and leaving the warning out on cars not so equipped would be a little silly.
I'd say check that the speed sensor to the tranny is plugged in... and likewise with the front sensors. After you check for codes, as garrettrowe mentions.
Not if you top it up!!!GrimJack said:Agreed. The brake system is designed so that significant pad wear will drop the level in the master cylinder enough to trigger the fluid warning.
bigaaron said:Well, from what you are describing it may be prudent to take the car to someone who can correctly diagnose the problem rather then having your brakes go out and you causing an accident. If you know the brakes are bad and you keep driving and someone gets killed........
