well when i got the car it had an aftermarket cd player and the antenna doesnt go up or down. Im assuming that the stock player sent an elecrtical current when it was switched to am or fm? how do i set it up that way with an aftermarket head unit?
bigal0043 said:well when i got the car it had an aftermarket cd player and the antenna doesnt go up or down. Im assuming that the stock player sent an elecrtical current when it was switched to am or fm? how do i set it up that way with an aftermarket head unit?
bigal0043 said:im thinking ill just pull the antenna out of the slot a little bit and call it a daykinda like in you sig pic brad92t
supraman7mgte said:or just use the AM antenna in the rear window you'll need an adaptor fro mGM or something like that eliminates the need for the stockker
