Alright, so I recently got my car running after my winter project. sp61gtbb, maftpro s/d, plugs bkr7e 0.28, wires msd 8.5, new i/c piping, rebuilt tranny. It had been running fine for a couple days. I took it up to school yesterday, 50miles, and the trip was fine. Even on the way back, the car was still running good. But I did notice that it was running rich under part throttle. Anyways, I stopped at a firestone tire dealer to pick up the tires I had ordered, and when I got back in my car to start it... It cranked but didn't start.
Also while cranking it sounds like it stops cranking, almost like a backfire?
So after sitting there and thinking for a while, I come to the conclusion that maybe it's flooded, or the plugs are already full of deposits from running rich during that trip. So this morning I went and installed some autolite 3923s. But they did not help. But I also noticed that after the car has sat for a little while, It will crank longer before "backfiring". And, if I pull the EFI fuse and crank it, it will crank all day long, and sound normal (not like it has no compression).
I have not seen boost with this turbo yet, so it's not like I was driving it hard. And when I got to the firestone, It shut off just like normal, no wierd sounds.
I miss my supra! two days of driving doesn't make up for 6months of downtime over winter.
Any suggestions would be wonder full. I think the next time I go, I'll somehow disconnect the fuel pump, and crank it with just ignition, and hook a timing light up to it. and maybe before that i'll wiggle the cps wires, although I haven't had any problems with that, and the cps was not removed this winter...
ugh idk... I need a break.
