Am confused please help with firing order
natedog910
27
US
#1 goes to #cly Wright then #6 to cly#6 and so on
Am getting confused because I see to firing order 153624 and 163425
For a 7m-gte 92
Sent from my SM-N910T using Tapatalk
SupraTrbo89
228
West Chester, PA
The "coil pack" firing order you have is correct. If you label the cylinders 1 to 6 from the radiator to fire wall respectively thats how you will match up the spark plugs wires.
The coil pack spark plug wire order is not the cars firing order .....which you have listed correct above also.
Koenigturbo
1,337
Oxnard CA
Kinda cool how the form works, I logged in just to find out this thread is exactly the answer I'm looking for, I just happened to have the exact problem.
Koenigturbo
1,337
Oxnard CA
so another words number 5 plug wire goes to number 6 coil terminal 3 goes to 3 coil number 6 plug wire goes to number 4 coil 2 goes to 2 coil and number four plug wire goes to number goes to number 5 coil, is that right? or does it go1 to1 6 to 6 3 to3 4 to4 and so on.
cinderMK3
I want all the HAm
Apr 13, 2015
134
Akron Iowa
Wires attach the coil number to correlating cylinder
And if you are wondering, yes I do sell my art, and It's very expensive :p
8,871
For a 7m-gte 92
The coil that fires 1 and 6 fires spark in cyliners 1 and 6 at the same time. But only one cylinder is firing its air/fuel charge. This is why it is called "waste spark".
This is the cylinder firing order.
Sent from my archaic device known as a keyboard.
