almost done but....
Xtreme
138
Lebanon, OR
but I have a code 43... when I searched, I couldn't find any relavant info on what to do about this/the most common ways to fix, etc... so if anybody has any insight, help is needed.
My other problem may be more severe....when performing moderate right hand cornering, my car shakes and seems to oversteer, my butt tells me it's coming from the rear of the car, but that may not be the gospel truth. Things I've checked: Tire pressure, lug nuts, visual inspection of left rear suspension, everything seems to check out, from what I could tell, but there is definitely something amiss. Again, only right cornering does this, no symptoms at all when cornering left, and a gentle corner won't do it, you have to "carve" a little. Any ideas out there? Has this happened to anyone? Thanks for the input/ideas, help is appreciated.
Stretch
Tallest MK3 driver ever!!
Toronto, Ontario
Maybe it's bouncing a bit? Since the weight transfer to the left side of the car and more towards the front? I would think the rear right side would lift a bit and your tire tries to grip but sorta grips then bounces :icon_conf
eric
Xtreme
138
Lebanon, OR
Boy, I dunno about the tire bouncing thing, it feels more like a severe vibration than tires bouncing, plus I don't hear any noise from the tires.
