air ride suspension
What exactly are you looking for in air ride?
Nothing concrete because only a handful of people have actually thought about it. Really no gains other than pushing a button to raise the car. Which actually you can have fully adjust coils with small actuators to raise the car like on ferraris for like bumps and such.
They do make air ride coilovers. The actuators to raise and lower normal coilovers are extremely expensive and were developed because of the minimum height laws in Japan.
Yet again, another pay to play.
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
www.toyotafiberglass.com
I have supra cradles mounted on my custom "hot rod" frame , and I want the air suspension instead of the coilovers .
I have check out airride.com , and am most likely going to use those , but the upper A arm on the front is a very tight fit as the smallest diameter of air they have is 4" .
I guess I will just have to make my own A arm ? unless I can find a replacement .
I was hoping to find someone else whom has done this before
poodles , would you have any more info on the Japan system ?
RiyadYar
384
NY
give the guys at ridetech.com a call i know some people who used their system (highest qualit) let them know about upper A arm issue and hopfully they can get it fixed. when a friend was doing a ridetech suspension on a 69 buick when he had problems with some parts ridetech had him send it back and they had their engineers make a new part for him.
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
thanks .. I did .. Talked to Danny , but because it's an import , they really didnt know .
I think I can squeeze the 7000 in there , but it's width is 4" , and that is basically the opening of the front A arm , so there will be a little "touching" happening I think . I can also "sleeve" the bag , but it will then consistantly "wear" on that .. I might be able to take a little material off of the A arm to make it all work .. but I was hoping someone else had already been threw this , so I could see what they did ..
te72;1763625 said:
So, what sort of body is going on that frame up there? ;)
http://www.supramania.com/forums/showthread.php?27957-My-build-...
te72
Classifieds Moderator
6,602
WHYoming
So, you're building a custom framed muscle truck? Pretty sweet... 4wd, or just 2wd? Just curious, only browsed through the first 50 posts of your build, most of which were engine pics.
slacker
master mould maker
Sep 24, 2006
123
BC , Canada
yeah 2WD .. full custom !!
maybe I should do this instead .. holy FUK! .. can you say " drift" :)
---------- Post added at 09:05 PM ---------- Previous post was at 09:00 PM ----------
BorHor;1764478 said:
Here are some kits I found.
http://www.ksportusa.com/asp/air_suspension.asp
http://www.d2racing.com/content/products/basic_air_suspension
Ksport and D2 are probably exactly the same. I remember seeing another company but I am blanking on the name right now.
YIKES .. 3G for 2 front struts and an air tank .. seriously ? and thats there "basic" kit .. :aigo::yikes:
te72
6,602
WHYoming
Hah, you could probably forklift-steer with that much angle... and you know what they say, gotta pay to play? Might look into companies that are geared toward classic US cars. I know my brother was looking at bagging his Impala for something like 1500-2000 for the whole thing.
supraguru05
Dec 16, 2005
737
louisville ky
I would drill out the upper ball joint mount on the spindle and ream it to fit a standard GM ball joint. Then use circle track upper control arms and you should get alot more clearance. Check out speedwaymotors.com for control arms. You would need to measure your spacing to get some.
