Hello,
I installed a Grant Wheel with Grant hub adapter and wheel adapter. Install was fairly smooth, I even modified the horn following some instructions I found on SM last week. Horn doesn't seem to want to cooperate, and I figured that was no big deal...my turn signals however, I could really use those. To be honest, I'm not sure what went wrong with the turn signals. I know there is a black plastic(ring?) around the steering column and it's pushed down a bit due to the pressure I applied to install the hub adapter. I'm assuming this could be linked to the turn signals causing them not to function. I've done several searches and can't seem to find anything relating to this. Someone else surely has run into this issue somewhere down the road. Does anyone have any suggestions? I'm hesitant to take the wheel back off, i think this is my only option though.
