After cat O2 sensor
67rstbkt
65
Reno, NV
Does anyone know if the after cat O2 sensor (California emmision?) on an 88 Supra (7MGE) is just a standard 4 wire? The direct fit replacement is pricey and I have a mounting plate to adapt a standard threaded O2.
Thanks
craigh310
76
Gardena, California
I replaced mine with one from Rockauto.com., 88 N/A, CA emissions. Spendy, about 170.00. Error code went out. Never checked the dealer for a replacement.
67rstbkt
65
Reno, NV
935motorsports;1268423 said:
It's your average 4 wire sensor. If you can get a universal screw in one, with the adapter, and cut/splice your original connector to it, you will be in business.
That's what's in there right now, I just wanted to make sure there would not be any issues later on.
Thanks
