Aem V2 - VS - Aem V1
Flateric
946
Calgary, Alberta, Canada
How much of a benefit are the new features, really, in a real world sense, am I going to miss not having them if I go for a 6860 or stinger setup.
It seems that there is a pnp for the factory 2jz harness. This is from their webpage....
Series 2 EMS for Toyota Supra Race Cars!
6/1/2009
AEM INTRODUCES SERIES 2 EMS FOR TOYOTA SUPRA RACE CARS!
INCLUDES NEW AEMTUNER SOFTWARE FOR IMPROVED EASE OF TUNING
Hawthorne, CA, May 28th, 2009—AEM Performance Electronics is pleased to introduce its
Series 2 Plug and Play Standalone Engine Management System for Toyota Supra 93-98 twin turbo.................
# Plugs directly into the factory harness. No rewiring necessary.
# Uses all the factory sensors.
# Includes start up calibrations.
# System is fully enabled and unlocked - Never pay for upgrades!
# Context sensitive help eases tuning process.
# Maps can be password protected by the tuner to prevent unauthorized usage or sharing.
# Runs on Windows-compatible software.
# 12 peak and hold injector drivers (Supra only).
# 8 direct-fire coil outputs.
# 16 general-purpose outputs.
# 8 definable switch inputs.
# 4 EGT inputs with fuel control.
# 1MB of internal data logging.
# Electronic boost control.
# Full idle control.
# Programmable traction control.
# 8 coil outputs.
# Software definable knock control.
# Two step launch control.
# User configurable soft-cut rev limiters.
# Wet or dry nitrous control.
# Tune using new USB communication port or serial port.
# Works with all AEM gauges.
The last ems I ran was on my old setup and was a 7mgte with full hks gear...Fcon,vpc, boostcontroller, fcd, timer etc. And of course this was piggyback.
Idon't really want to sweat the couple extra bucks for the series 2 if its going to save me any kinda headaches at all. A quick sum up of my new 2jz setup are...
GT4088r
850cc injectors (or possible 1000cc)
lightweight flywheel, aluminium driveshaft
4" engine back exhast
3" IC piping
big front mount intercooler
six puck clutch
etc..... gives you the idea the direction I'm heading anyways.
You can check my streetfire page if you wanna see some pics and such from awhile back of the build.
http://user.streetfire.net/profile/Flateric.htm
Thanks for any input guys.
2JZ_MA70
191
Cleveland
If I was you i would wait and get used box that someone upgraded for fraction of the cost. Unless you have 1600cc you dont need the peak and hold. The ignition outputs can be modified and on the old EMS1 so you do get to remove the igniter if you so wish. Obviously the procesing speed the USB conectivity is nice but I dont think it is wort the extra cash... Unless you have to have it.
What trans and clutch are you running?
