AEM V2 Timing issues 7mgte
Neonaj
5
Minnesota
Hey,
I am wondering if anyone can help me or is familiar with AEM v2 and how it works. I am looking to see how I can change my timing because my car is way off, and it will not start up. My set value for ing timing is -17, that is how it came preloaded on my ECU. I need to change that value to at least 14 so I can get the car started, anyone have a clue on how to change that parameter, it wont let me. It's on a 1991 turbo supra. Thanks
Enraged
A HG job took HOW long??
21
Victoria, BC, Canada
go here: http://www.aemelectronics.com/products/support/instructions
download the instructions for your v2 model.
go here: http://www.aemelectronics.com/produ...ries-2-programmable-engine-management-systems
There is a first start/setup procedure that you will need to follow. The basics are that you match the engine timing to the ECU timing, using a timing light. It's not hard to do, just takes some time to get it right. I have a v1 so the software is different on yours, but it fairly straight forward.
If you aren't comfortable doing this yourself, have the car towed to a tuner.
