aem tru boost
89supra7mgte
797
colorado
I have the tru boost set up correctly. Set the gae to 7, which i believe is for the stock wastegate spring right? I have noticed that my boost starts around 3k on a 57trim, is this correct? or can it be in the controller settings? Having no real problems just wondering if there is a way to get the spool up time faster.
Ok so i found the manual and it says set the spring psi, and it will keep solenoid open from 1psi until boost reaches selected value. So would i want to lower this to get faster spool time? and if so what might i bee looking at as far damaging something goes?
89supra7mgte
797
colorado
2.5 inch i/c kit, recirc bov, walbro 255, 560cc, lex afm, safc 2, for 3 inch turbo back, mhg, arps, lc1 wideband, clutch, 1 piece driveshaft, afpr, thinks that is it. got all the major ones listed as far as supporting mods go.
