Aem Map Needed
Bomberillo
141
Lynwood
Ok guys just thought Id try this out. I need to get a map for my V1 Aem Ecu 30-1110 for an 87-88 supra 7mgte. Reason im asking the community is I have no money and the car is just sitting ready to go(minus a map). I cant see myself running into a wad of money anytime soon and I cant stand not driving it. Here are a list of mods
Rebuilt 7mgte:
Eagle rods
Wiseco pistons 9 to 1
All arp hardware
2.0mm hks stopper hg
1mm oversized valves
Bc spring and retainers
Port and Polish
264 cam regrinds
67mm precision turbo p-trim
Hks intercooler
Aem AIT
3 bar gm map sensor
Fidanza cam gears
Bosch 700cc injectors
Walbro 255 lph
Afpr
Thats a few of the mods done. If you can help me out let me know. Thanks in advance.
kwnate
Lurker
Jul 10, 2005
2,725
None of your fucking business
I have a map that was for a setup similar to what you have but it wouldn't work. Every car is different. You can download a base map for it. I'm not sure anyone will just give you a map. Sure its just a file, but mine cost me over $1,000.
Download a base map, set it up for your specifics and figure out how to tune it on the street so you can putt around til you can afford to have it tuned.
Bomberillo
141
Lynwood
Your right. I cant imagine anyone just giving away a map either. However this is a community where everyone likes to help each other out. I just though just maybe someone has the same setup and can give me a killer deal. After all its just a map and if the setup was to match you can make a quick buck. Thanks though Kwnate.
gixxer750
2jzget comingsoon!
Mississippi
my old car was set up pretty close to what yours was. It MIGHT run the car enough to drive it around.
Try a few of those. These maps were around the time I went to tx2k8, so if I'm not mistaken, it should be a somewhat ok tune.
EDIT - you will need to change the map sensor and injector types in the setup.
  • chrisp-030808.V1.19.cal
  • chris's current cal 3108.V1.19.cal
  • current cal 2 3108.V1.19.cal
  • race gas map up to 24 psi.V1.19.cal
  • hal6.V1.19.cal
Bomberillo
141
Lynwood
Thanks alot man. I will let you know if they work.
ae86ma70
119
Atlanta
Did any of them ever end up working? Just curious. I need a base map for speed density that is good enough to get the car to the tuner, about 15 miles away. I'm running a DM60-1 setup, so I figure those maps might have more than enough fuel for the short trip.
