aem/3 bar map and wideband please help me i have looked and looked
MINA
162
sacramento
hey guys heres the scoop:
got a 1990 mkiii
2jz na-t w/ 7m electronics
aem standalone 30-1110 (with jumper harness to convert from 88 to 90 harness)
gm 3bar
aem wide band
what am having a hard time with is wiring the three bar map sensor i know that there is a G(ground) R(power) and a 0.5v off the 3 bar any one know these wires on the 1990 7m harness from the maf plug?:aigo:
also with the aem wideband the blue 0.5v that goes to the aem unit the record the afr's were would i splice that in too. what wire :3d_frown:
please help me out guys :: angry ::
thanks alot any questions or corrections please let me know thanks:cry:
Enraged
A HG job took HOW long??
21
Victoria, BC, Canada
go here: http://forum.aempower.com/forum/index.php/topic,21539.0.html
get the pdf for your model, it has all the pinouts listed.
also, when hooking up and setting up your wideband in the aem software, unplug the 02 sensor and the wideband will output 2.5V = 14.7 afr. then you have to use the aem software to scale the input so it matches, meaning 2.5v on the wideband = 2.5v on the aem software display. once the scale is set, you can plug it back in and it should read properly. we had this issue with my car.
