I was doing some searching and couldn't find any good threads. From what I could find supra sport said +3 advance and -1 retard. I don't know which is intake or exhaust. Does anybody on here know.
gravesdu_99 said:I was doing some searching and couldn't find any good threads. From what I could find supra sport said +3 advance and -1 retard. I don't know which is intake or exhaust. Does anybody on here know.
7M-fanatic said:Set themn at Zero, and then play....
2-4 degrees retard on both will give you more top end power.
2-4 degrees advanced on both will give you better bottom end.
Then try combos.
Remember,
you need to re-time the ignition every time you move the exhaust cam.
Advancing the exhausT, and retarding the intake will work well on a stock 7M turbo.
gravesdu_99 said:Heres a crazy question. With the cam gears which way do you turn to advance and retard.
