Adjustable Cam gears
juggernaut
26
South Carolina
I'm planning to rebuild my engine next moth and I'm curently gathering up the parts that I will need. my understanding is that a Maft Pro can be used to adjust the engine timing. I have a Maft Pro, so what I'm asking is, Is there a need for me to purchase adjustable cam gears as well. Since is can be done via the maft Pro.
You can adjust ignition timing with the maft not cam timing. 2 different things.
If your using stock cams, cam gears are kinda pointless.
CajunKenny
PULL MY FINGER. PLEASE!
Nov 15, 2007
3,255
Washington
I politely differ with this statement. :)
I was on the dyno this past October and gained a little bit of HP even more TQ by adjusting the intake Cam. I didn't have enough dyno time to get the Exhaust Cam adjusted.
Here are some threads for reference...
http://www.supramania.com/forums/showthread.php?131313-Cam-Tuning-Help-Info
http://www.supramania.com/forums/showthread.php?126917-Looking-for-some-feedback-info-on-cams...
This thread has great info and all results were from a 7MGTE w/stock cams. My results were VERY similar to the results on this page.
http://mk3ukr-supra.net/cylinder_head_main.htm
^All of that being said, you will absolutely see higher gains from tuning upgraded cams than you'll see from tuning stock cams.
