accusump Q's
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I'm building a high hp 7m and was looking at getting an accusump setup. I need to know all the pieces i need and exactly how to plumb it in relation to a remote filter and oil cooler system. I'm using an upgraded oil pump and trying to do everything I can to protect this engine. Any help would be greatly appreciated.
Solenoid is handy but not essential, you need a -10 male T to screw into the accumulator.
forcefedsupra
aka, Turd Furguson
Jul 19, 2005
463
Jacksonville, FL
I will use an electric solenoid. I can see how everything is plumbed in your pic, but which is first from the engine and which is last item before the return?
I just put the full amount in then crank for a couple of seconds with the IGN disabled.
(I also used to blow out the Remote filter Cooler, Accumulator and Lines to ensure a 100% change instead of a 60%er)
hvyman;1667591 said:
I want a 1qt just for pre prime before cold starting. Shouldnt be too bad to mount.
Might do better with a momentary button to kill spark/fuel while cranking if you want to prime, I found cold/thick Oil isn't keen on moving out of the accumulator on it's own..
(had my MoTeC set to crank xx times when temp was lower than 60c)
Only way I could get it to work well was run the engine at 3000+ close the solenoid then shut the engine down so you had a full high pressure charge the next morning, problem with this is I preffered the accumulator flush Oil through the turbo after shutdown to pull the heat away from the core so the above wasn't an option for me.
