The vacuum hose on the bottom of the accordion pipe is diconnected . What is the unit called where the vacuum hose goes into from the accordion pipe ? What does it do ?
7m2ner said:and i also had to plug the lower hose on the accordion pipe, because I never knew what it was for. I had never thought about that, because when I did the N/A to turbo swap I used the non turbo power steering pump, and since I get a bad idle at times, could that be the cause of the bad idle problem? thanks ricardo
