Access hole on drivers side firewall?
gotsomegetsome
Age Quod Agis
Mar 31, 2008
210
san jose
Is there any access hole on the drivers side firewall that is large enough to fit a <4mm vacuum hose in but not any larger than about 5mm.
any answer in that range is fine. I just dont want to have to drill any holes, which in time may lead to rush and etc..
92nsx
2,957
Clearwater, MN
:rofl: you what the hole to be larger then 4mm but smaller then 5mm. Thats a .8mm window (that s .031"). Its not going to happen. Get you self a drill and some elbow grease.
akito
Keep Laughing.You're Next
Jul 31, 2006
1,568
Springfield/Va
yes there is one, to the bottom left of the brake master cylinder. Theres a grommet that you can take out and cut enough to fit what ever you needed to. The grommet is about 1.5" diameter.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
Well if you didn't help the OP out, at least you helped me, because now I know where to put my 4 gauge wire through for my amp wiring. Thanks! lol
CyFi6
Aliens.
Oct 11, 2007
2,972
Phoenix
www.google.com
If you have a manual that's where the clutch master goes. I run all my wires through the hole/grommet Toyota made which is under the fender. All you gotta do is remove the drivers side wheel well and you have full access to it.
suprarx7nut
YotaMD.com author
Nov 10, 2006
3,811
Arizona
www.supramania.com
This.
The access hole for the wiring can be used for a few more things. It can be a pain to fish the lines through, but its definitely doable.
A. Jay
Search.
Jun 3, 2009
671
Bay Area, CA
CyFi6;1522352 said:
If you have a manual that's where the clutch master goes. (...)
:icon_sad:
CyFi6;1522352 said:
(...)I run all my wires through the hole/grommet Toyota made which is under the fender. All you gotta do is remove the drivers side wheel well and you have full access to it.
:icon_bigg
lol thanks
akito
Jul 31, 2006
1,568
Springfield/Va
well at least i help the auto guys like me :) The access hole for the fender definitely is really nice too.
adampecush
Regular Supramaniac
May 11, 2006
2,118
Edmonton
suprarx7nut;1522355 said:
This.
a coathanger makes fishing extremely easy.
