Hi,
before my project started I had ABS error codes and I forgot to take a look at these while my supra was in a garage. The "ANTILOCK" light is still on so I think I have the same codes now.
The codes are:
#32 - Left front wheel speed sensor signal malfunction
#34 - Open circuit in front speed sensor
So my questions are, is it possible that these two error codes are linked together so if I have a corroded connector for the left front sensor so that there isnt a closed circuit, only one wire has a connection. So this would generate code 32 and 34 at the same time?
What are the usual faults/solutions for these error codes?
Bad sensor - Change the sensor?
Corroded connector - Clean it?
anything else?
Thanks /Marcus
The codes are:
anything else?
Thanks /Marcus
