A340e Hybrid transmission signal questions
Raven97990
230
Georgia
www.speedforsale.com
I am currently building a Hybrid A340e, and my ECU requires a input of 12 pulses per output shaft revolution- but I am using the MK III tail housing and sensor for ABS function, which outputs 36 pulses before revolution.
Is the speed signal from the cluster to the ecu 12 pulses per output shaft rotation, or does it output 4 pulses? I've not had luck finding it in the book and before I make a fancy electronic blocker to reduce the 36 to 12 I wanted to check in with the other experts.
May 18, 2007
704
Aarhus
