A crack in an exhaust port = useless head?
eraezer
849
9
Stockholm, Sweden
Hello,
when I started porting my exhaust ports today I found a small crack :( What do I do now? Is the head useless?
Here is a picture:
bioskyline
1,236
powell river bc
id clean it up and sand that area a bit (ie start the port and polish process) and see if its just a surface crack or if it goes deeper. could possible be welded. if not then it will need to be replaced.
eraezer
849
9
Stockholm, Sweden
the port process started before I took that pic. So I have already tried to grind it down.
The ports were black before and that's why I didnt see the crack until now.
The crack continues out to the manifold mating surface and stops where the black ring stops.
I'll try and take a better pic the next time.
This is bad news :(
Typhoon
208
ACT
Worst case, it will weld up easily. Given that it's at the edge of a casting, it will both be easy to prepare and weld and not introduce any real stresses into the casting. So don't stress out about it. If you get it welded, you can get the manifold surface machined too.
Could be signs of a weak head. Migh be better to find another one. There not much either.
eraezer
849
9
Stockholm, Sweden
hvyman, that's a good point.
Since I'm spending a lot of my hard earned money (still in school, working mostly during the summer break = not so much money) I don't want this to fail due to a shortcut.
I picked up another head yesterday which is in far better condition overall and no cracks :) But the exh. studs are thrashed, so they will be helicoild.
I will keep the old head and weld it myself when I have access to some better equipment.
Typhoon
208
ACT
I wonder how many here have any actual experience with anything to do with engines? It will cost $40 or so to get that welded and another $40 or so to have the exhaust face machined.
As for a sign of a bad head, nonsense.
NashMan
WTF did he just wright ?
Aug 5, 2005
4,940
17
Victoria BC
radiod
1,342
Abbotsford, BC
I'd get it hardness tested to see if the head has annealed. Granted, the exhaust ports are going to always be the worst, but not a bad idea to get the rest of it checked out. Last thing you want is cracks between the combustion chamber and coolant passages :(.
