a/c question??
supra_fast
FN Fast
May 13, 2006
128
Calgary, Alberta, Canada
i just bought a 92 supra with a jdm 7m-gte. now the car originally came with a/c. the jdm engine however did not have an air conditioner on it. so my question is can i put an air conditioner on this jdm engine so my car can be cold in the summer time.
Thanks
Travis
Dan_Gyoba
Turbo Swapper
Aug 9, 2007
1,836
Alberta
www.gyoba.com
Absolutely. The block will still have the mounting locations for the A/C compressor, and the balancer/pulley still have the location for the belt. If you're using the domestic ECU/wiring harness (Which you should be, since the JDM one has the ECU on the wrong side) then it will even have the idle-up for the A/C signal.
