92 steering wheel in pre 89?
Sparkynutz
Sad previous supra owner
Feb 27, 2006
217
Waupun, WI
I can't stand steering wheels with a spoke in the bottom center because I like to put my hand there while driving and almost all aftermarket ones are like this as well and dont have cruise control on them.
I tried searching to no avail. Has anyone swapped a 92 steering wheel into a pre 89? (I have an 88)
I have a spare steering column from a 90na that I can hack up and modify if I have to.
BorHor
2JZ-GZE
Jan 10, 2006
6,181
San Jose, CA
I remember seeing a write up for this but it is basically plug and play. The air bag wont work, and you will have to mod the 4 pin connector for the horn and cruise control that the 92 wheel has because it is only 3 pins on the pre 89 wheel. I think all that was needed to be done was cutting one side out of the connector so it has room to slide in.
*edit* http://www.supramania.com/forums/showthread.php?t=60
I guess there is more work involved if you want everything to work.
Sparkynutz
Feb 27, 2006
217
Waupun, WI
thanks. its a good start :) im sure I can figure out the wiring. I just want to make sure it will bolt up. only bad thing is that he doesnt mention air bag steering wheels, only non-air bag.
also wonder if the mr2 and supra steering wheels are the same?
*edit* wheel I had in mind- http://cgi.ebay.com/ebaymotors/Toyo...ryZ33704QQssPageNameZWDVWQQrdZ1QQcmdZViewItem
becauseican
Vancouver
www.bicperformance.com
Ever scince I dod the 89+ steering wheel swap my horn hasnt worked, I even just swapped the 89+ signal stalks and everything....I just am to busy to take the time to fix it LOL, I can hear a relay clicking behind the dash when i push the horn button. Which wire is the horn wire?
