Hey guys i had a few questions for someone out there, hopefully someone can help lol
1. As soon as you start the truck, it idles at im guessing somewhere are around 3k and nevers drops down. idle set screw is all the way out of adjustment, I have been thinking it was a major vac leak, but i have sprayed carb clean all around the motor, with no changes in rpm. Any common problems with this?
2. My clutch/Brake pedal assy is fubar. the bushing for the clutch rod wore out and now barely engages the clutch at all. i Found a similiar pedal setup with what looks like only one difference. on mine the spring for the clutch is closer to the floor, and on the one i found.. its closer to the dash. i havent gotten a chance to actually pull it out and compare. but any advice would be great.
