89+ Climate Control Problem
SupaMan
Want The Boooooossttttttt
Oct 12, 2006
1,101
Cape Coral,Florida
Ive had an 89+ climate control in my 86.5 for over 2 years now and the lights have always worked at will, If you push on the front panel of the controller they will turn on randomly and stay on till you hit a bump then go off, I always thought that id purchased a faulty controller and put it off, I recently acquired another 89+ climate control that does exactly the same thing, Could it be the wiring in the car and not the climate controllers?
Are the lights being funky a common problem?
How can i fix these controllers if they are the fault?
Thanks.
Supra469
495
Maryland
Now might be a good time to open up your CC and replace the stock bulbs with LEDs to fix and upgrade your lighting problem.
