Ok here's the deal....I have a 89 mkIII that i just purchased that i couldn't turn down. The car had a 7mgte in it when i got it but just the block and head everything else was striped of the engine. I have just recently pulled the gte out so it can be built outside of the car and I put my 89 7mge engine in with the ecu and engine harness from my 89ge. Now for the problems I am having, first is that when i put the key in the ignition and go to crank it over i am not getting any power to the starter. I have checked the starter by jumping it with a screw driver and it does engage the starter. The next ? is also to go along with the ignition problem is i am not recieveing any power at the fuel pump w/ the key in on possition, when i jump FP w/ B+ i can hear the FP kick on and hear fuel in the rail....so for the time being i ran the starter to a switch and jumped FP w/ B+ just to see if i could get the engine to start but all she does is crank over and not fire...I have checked the timing numerous times and every single fuse numerous amounts of times, all grounds, all connections, and no codes and i am stumped!!! Could this have something to do with the fuel relay possibly going bad on the passenger side firewall? But why would it not engage the starter???
I apologize about the story book post guys first post and wanted to make things as clearly as possible.
