Hey guys, I just bought my supra a few weeks ago. It was hardly running due to someone swapping in a Lexus afm and not changing the injectors. I got that issue corrected and took it for a ride. the car runs just fine while moving and seems to miss slightly when my foot comes off the gas. It won't overheat while going down the road but will overheat if I stop at a stoplight. I know for a fact that it is because it is missing the mechanical fan all together. the fan shroud is all crunched up and half missing. I was wondering if it would be cheaper/better to just run the contour fans or try to find a fan shroud and mechanical fan.
Now I know everyone is going to chime in about flow rates and how the climate effects it. I only use this car around town. It is not a race car. If the fans from a contour will keep it cool in rush hour traffic that is what I want to do.
Also if I do go with the contour fans how do I go about wiring it in? It seems like this is a common thing to do so I was hoping there's some info on how to get it to work properly in the car. Do I use existing wiring or run my own, and if i run my own would it just be better to put them on a key-on source? I'm unsure if they had more than one speed on them and if they do it would be great if I could get the high speed to work when needed, even if it is on a switch in the car.
Thanks for the feed back,
-Matt
-Matt
