As you probably already know, figure everything out before cutting any wires.
Also in my car, the positive had wires coming from the Low beam and going to their own circuit (it only powered the relay), so those wires you cut off from the relay, you'll want to connect the two cut wires coming out of the same positive terminal of the relay, if yours is wired like mine.
I hope what i said makes sense, the positive has more than one wire coming out of it.
