Just a Background, ran fine about a week ago, pulled it off the road to change the turbo and a couple of other things.
Pulled off the intake manifolds thinking I had a leaking gasket, turns out it was a broken pintle cap on the injector. Fixed all that, put it all back together, now won't fire. Cranks over, a couple of times it has run for a few seconds and then died. Also put some BCP7ES plug in it.
Pulled the codes, code 51 and code 14.
I checked everywhere I could think of for loose wires on the CPS also on the coil packs. Change coil packs and back to original plugs, no go. Weird thing is number 2 and number 5 spark plugs were like brand new, while the rest were fouled up.
I have pulled the battery power and let it sit for a while and then re-tried, nothing.
Have also tried tow starting it, nothing.
Anyone have any suggestions?
I am pulling my hair out and have all about 2 hours to get it going before it goes in for a tune
