7mgte need help
curtis7mgte
circleville
i have a 88 supra turbo and haveing issues with it sounds like its got a dead cylinder but it dosen't. It has low compression in cylinders 2,3,4,6 but 1 and 5 have 0psi. The bottom end is fine i ran it with my backup head while i had my orignal head redone for drag racing i did the comp cams spring upgrade i dont think the valve shims are not adjusted right and if so how do i adjust them
curtis7mgte
circleville
my bad another mkiii i over looked it btw i think the valves need adjusted did a compression test and cylinders 1 and 5 had 0 and befour the rebuild they were fine
Backlash2032
1,823
Nebraska
If you didn't touch the valve adjustments, then its possible you need smaller shims and they're constantly holding your valves open currently. The process is in the TSRM for adjusting them.
curtis7mgte
circleville
it is the shims for sure i can't even get a feeler gage in there is how bad it is on cylinders 1 and 5 and the others are not in spec. Does anybody know the part number for the valve shim tool or were i could get one
