7MGTE MPG
Alang
55
Las Vegas
I'm thinking that this says that the AFM, O2 sensor, and TPS are set and working OK? Comments, suggestions?
LV-LA Road trip MPG report:
outbound 3500rpm 90 MPH cruise 12.6 gal, 255 mi = 20.2mpg
return 3000rpm 80 MPH cruise 14.3 gal, 316 mi = 22.1 mpg
Full A/C operation
My prior Local/blvd MPG is >17,<19 w/ AC.
This is 85 7mgte auto w/ 4.10 rear, 3" Reintegrated DDP and exhaust to an estimated 2.75 or 2.50 Muffler and the timing may be 10 BTDC. (I think I dropped it back from 12).
At previous tank, did an ECU reset.
Other history:
I had checked and reset the TPS.
I had the CPS rewired to a used output connector piece. Started OK till a few weeks ago till it didn't at all and I crimp wired a used receiving side connector piece. Instant difference - with a quicker toyota 1 crank fire-up with a seat of the pants bit more vacuum and low cruise throttle response. (I have another thread about this)
zachm611
Beauty In Disguise
Apr 15, 2006
543
new mexico
last time i went to roswell i got about 30mpg on the highway, i have 87 turbo, automatic, pretty much stock except for 3" ebay downpipe.
mkIIIman089
Ohio
^Won't hurt anything under cruise. Man, 27/32... that would be tough for even me to beat. At that speed the revs must be just right for best efficiency. (I'm foolishly assuming that you have done your math properly)
pimptrizkit
thread killer
Dec 22, 2005
1,572
vancouver Wa
yeah i did, i filled up in vancouver and drove to tacoma/olimpa area
i got 33 on the way up there and richened her up a few points on the way home and got 27, i made it there and back on just over a 1/4 tank
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
I get ok city.. i'm guessing around 20. But when i go on the highway @ 70 the gas just stays there... i feel i could go forever! so i'm guessing about 26+
88 Shimed wastgate to ~8-9 psi replaced curved upper hard pipe with a 2 1/4inch steel peace and no resonator with a K&N replacement air filter and mobile 7500. Oil does really make a diff.. its small but its there (not saying mine is good) and i'm on 10-30
P.S. is it me or is 70 a sweet spot... and 90 is the same shit too! 80 sucks tho, every time i go 80 i see my gas go down quick.
MKTURBO3
93
NEWYORK
damnnn im seeing like 12 miles to the gallon rebuilt motor i dont boost all the time only sometimes. what areas should i be looking at ? not to steal ur thread but im going broke !!! ~
NeatOman
Never know enough!
Oct 5, 2006
233
Addison, IL
/\/\/\ WRONG! getting poor mpg wile @ 80... good mpg @ 90 HA HA HA (85+)
My uncle has a Lincoln LS V8 that when he cruses @ 75 he gets only about 18mpg (it tells you) and when he cruses 90+ he gets 26+... now that is retarded. But thats because the trans doesn't go into OD until 85+
Cedrock15
The Sarcasm Specialist
Sep 29, 2005
126
Bucks County, PA
Nick M said:
Only a Supra owner would start a thread about getting poor mpg while doing 90.
lmao
I get like 13-15 mpg city, highway, school zone, no matter where. When i go above like 60 its probably around sing;e digits...:nono:
dok33
My fuel pump precedes me
Apr 16, 2005
934
Austin, TX
themadhatter said:
where in the hell can you guys cruise at 90 the fastest you can get away with here in va is about 70 lol
Things must have changed since I left Blacksburg 2yrs ago, the left lane on I-81 used to run 85-90MPH, that was alot of fun in a lifted 4cyl 4-Runner :naughty:
AaronsSupraMKIII
254
Athens, AL
I'm getting around 13MPG. Is there something that needs tweaking? I was hopeing for at least 18 to 20. Its getting expensive driving to work and back every day. (50 miles round trip)
